I am using autocad 2011.
I have created a basic cube and i want to start crossing selection in 3d wireframe by clicking in the square box visible in front view.
But instead of starting crossing it selects the cube.
In Autocad 2006 this was never a problem. How can i get the same selection settings of Autocad 2006 in Autocad 2011?
Also when you want to select the nearest point on the edges of the box it tends to select some 3d point in the cube rather than selecting a point on the edge. In Autocad 2006 it would never select any 3d point. How can i avoid this?
Please Help.
Sid
Also when you want to select the nearest point on the edges of the box it tends to select some 3d point in the cube rather than selecting a point on the edge. .... How can i avoid this?
For the first one, try specifying the Crossing method [type a C] before your first pick. [If you're already doing that, I wonder whether your picking device is faulty, and is registering two picks when you press it only once.] Also, what is the cube: a 3DSolid? Six 3DFaces? Six [2D] Solids? 12 Lines? A Polyface mesh? Etc.
For the second, I'm not quite sure what you mean, but are you specifying Nearest object snap?
