AutoCAD 2010/2011/2012
Valued Contributor
MatthewB80097
Message 1 of 6 (341 Views)
Selecting items not working properly
341 Views, 5 Replies
09-21-2012 03:49 AM
Recently I have started having this annoying problem where I select something and it shows it is selected by the grip but in reality it hasn't selected it as can be seen in the properties box.
Cancelling the selection with the ESC key doesn't work
regen doesnt' work
regenall doesn't work
audit doesn't find anything
Qsave does work but I would prefer not to use it due to sharing drawing xrefs with others means that they constantly have to keep reloading the xrefs
Have tried reinstalling autocad but that doesn't make it work.
Was wondering if it may be something to do with the graphics? - Currently have a NVIDIA Quadrow 3500 which is probably not the correct one.
Any suggestions?
M_Hensley
Message 2 of 6 (337 Views)
Re: Selecting items not working properly
09-21-2012 04:11 AM in reply to: MatthewB80097
This behavior can be caused by running a Windows registry cleaner. They do not work properly when you have AutoCAD installed. To fix you go to control panel, add/remove programs and select the repair option for AutoCAD.
Valued Contributor
MatthewB80097
Message 3 of 6 (288 Views)
09-25-2012 06:16 AM in reply to: M_Hensley
Our IT department ran a windows registry software on this problem and didn't find anything wrong?
Patchy
Message 4 of 6 (280 Views)
09-25-2012 06:26 AM in reply to: MatthewB80097
Read your 1st reply, the cause of it is the registry cleaner. Nothing you can run now that will fix the problem except repair or reinstall autocad.
Valued Contributor
MatthewB80097
Message 5 of 6 (273 Views)
09-25-2012 06:33 AM in reply to: Patchy
Ive had autoCAD reinstalled too due to another issue and the problem still occurs? Been happening now on and off for the last couple of months.
Patchy
Message 6 of 6 (268 Views)
09-25-2012 06:46 AM in reply to: MatthewB80097
If it has been happening now on and off for the last couple of months, turn off antivirus to see if it will happen again.
Certain anti-virus do it as it said here:
http://en.allexperts.com/q/AutoCAD-1029/properties-tool-pallet-2007.htm
