AutoCAD Forum
select text
5 REPLIES 5
wwwangeiei
452 Views, 5 Replies
select text
I have a lot of objet text, I want only select the text which contains "and" for exemple. Is there a caracter (* or # for exemple) which can remplace all the caracter? for now, i can only select the text objet which is totaly "and".
thank you
Tags (2)
5 REPLIES 5
3wood
in reply to: wwwangeiei
Surely you can.
Just use command QSELECT, settings as below:
wwwangeiei
in reply to: 3wood
thank you for your reply, but i have a version in french, the * did not work. Autocad consider it as a caracter '*', it can not replace the others caracters...
Kent1Cooper
Read about the (wcmatch) function in Help to find out what the wildcard character for any number of characters is, if it's not * in your version.
Kent Cooper, AIA
doni49
in reply to: Kent1Cooper
If you're using the french version, that sounds like it would be in @braudpat's wheel house.  Hopefully he'll get a chance to respond.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
braudpat
Hello from France
And why you don't use/try the FIND (RECHERCHER) command on your Texts / Attributes / etc ?
Please look at my French Screen ... and the RED options !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
