I have a lot of objet text, I want only select the text which contains "and" for exemple. Is there a caracter (* or # for exemple) which can remplace all the caracter? for now, i can only select the text objet which is totaly "and".
thank you
Solved by wwwangeiei. Go to Solution.
thank you for your reply, but i have a version in french, the * did not work. Autocad consider it as a caracter '*', it can not replace the others caracters...
Read about the (wcmatch) function in Help to find out what the wildcard character for any number of characters is, if it's not * in your version.
If you're using the french version, that sounds like it would be in @braudpat's wheel house. Hopefully he'll get a chance to respond.
Don Ireland
Engineering Design Technician
Hello from France
And why you don't use/try the FIND (RECHERCHER) command on your Texts / Attributes / etc ?
Please look at my French Screen ... and the RED options !
Patrice BRAUD
