Section marker's text is not aligned with marker. Its like the text is mirrored with the actual section marker. How can i align the text back with the section marker.
Don Ireland
Engineering Design Technician
i have completey deleted everything from the drawing other than a few of the messed up section makers and the file is still too large for me to upload here. is there some other way for me to fet the drawing to you?
If you've deleted everything else and it's still too large, then I'm guessing you didn't purge. And note that it sometimes takes 3 or more purges to get rid of everything. It'll get rid of a bunch of stuff on the first run -- but then because things were purged, new items are no longer referenced and can therefore be purged.
Then if it's still too large, upload it to dropbox, mark it as "Shared" and post a link to the file.
Also don't forget to answer question 1 & 2 above.
Don Ireland
Try ATTSYNC
In the future, for better help with AutoCAD Architecture objects, post in the AutoCAD Architecture General Forum
