AutoCAD 2010/2011/2012
New Member
russgrover16
Message 1 of 21 (4,210 Views)
Scroll button on mouse will not pan
4210 Views, 20 Replies
01-30-2010 09:18 PM
I just installed Autocad 2010 student, and now my microsoft wireless mouse 4000 will not pan when I press the scroll button. I have read a few older post that talk about Mbuttons but I can't find how to change my Mbutton from 0 to 1 or whatever it is supposed to be. Does anyone know how to fix this problem. I am not the most computer savy so please make it as simple as you can I am retarted when it comes to settings. If anyone can help me I would greatly appreciate it thank you.
*Nathan
Message 2 of 21 (4,210 Views)
Re: Scroll button on mouse will not pan
01-31-2010 12:07 AM in reply to: russgrover16
MBUTTONPAN :-)
wrote in message news:6327577@discussion.autodesk.com...
*George Drayton
Message 3 of 21 (4,210 Views)
02-01-2010 12:09 PM in reply to: russgrover16
The problem is usually related to settings in the mouse driver. The
centre button/wheel must be assigned to "middle button" or some other
terminology - usually the driver's default setting are incorrect for
AutoCAD.
George Drayton CD-CAD Ltd Christchurch New Zealand.
New Member
rockies3310
Message 4 of 21 (4,210 Views)
03-17-2010 04:42 PM in reply to: russgrover16
i can't get my middle mouse button to pan either. and i changed the mbuttonpan command to 0 then back to 1 and i can't pan with either.
*George Drayton
Message 5 of 21 (4,210 Views)
03-24-2010 03:43 PM in reply to: russgrover16
You usually have to set your mouse driver so that the middle
button/wheel is configured to "Middle Button" or similar. mbuttonpan
should be 1. Different drivers use different terminology.
Valued Contributor
mail
Message 6 of 21 (4,210 Views)
03-31-2010 04:16 PM in reply to: russgrover16
I am having similar problems. My "mbuttonpan" is set to 1. Only in SOME files, I am not able to scroll using the mouse wheel. There is a bar on the side and bottom that needs to be selected and dragged to scroll. How do I get back to the wheel scroll? Some files scroll fine.
*Dean Saadallah
Message 7 of 21 (4,210 Views)
03-31-2010 04:27 PM in reply to: russgrover16
>>>...Only in SOME files...<<<
Could this be a rotated UCS issue? Can you share one such file here?
Dean Saadallah
http://LTisACAD.blogspot.com
New Member
bsugiyama
Message 8 of 21 (4,210 Views)
04-03-2010 11:50 AM in reply to: russgrover16
running windows 7(64), autocad2010 and microsoft intellimouse optical usb-after loading new dirver via internet the wheel is defaulted to flip.
it does not have autoscroll app. is this a autocad condition?
*Dave Jones
Message 9 of 21 (4,210 Views)
04-03-2010 12:53 PM in reply to: russgrover16
not if it happened after installing a new mouse driver. You need to set
your mouse software to have your wheel as "Middle Button" for AutoCAD or
whatever is similar in the MS mouse setup (I use a Logitech mouse).
Dave - DDP
Acad 2010 and Revit 2010
Win 7 Pro 64 bit
Intel I7-860 @2.8GHz
12GB DDR3 RAM
GeForce GTX260
Active Member
NicoleJordan232
Message 10 of 21 (1,564 Views)
08-15-2013 09:31 AM in reply to: russgrover16
I have an HP pc and an HP mouse, keyboard, and monitor. But, my mouse is totally backwards. if i scroll down ACAD scrolls out if i scroll up ACAD scrolls in. If i press the pan button, it will stick zoom in place.  I really need to figure this out, i have tried researching it on google, even on here. I cannot get any of my work done with out this fixed. (I am using ACAD 2011 Mechanical Engineering edition). Any help will be greatly appreciated!!!
Announcements
Need installation help?
