AutoCAD 2010/2011/2012
ArchD
Message 1 of 3 (491 Views)
Scale X and Y, but not Z
491 Views, 2 Replies
12-01-2009 09:10 AM
I have a topo with some spot elevations in a drawing that was sent to us from another company that I want to xref into an existing drawing of ours. In the drawing they sent, its not in the correct ucs or scale that the original drawings are in, but the elevations are correct. Is there a way to scale everything by the x and y axis but not the z axis?
Archie Dodge
Civil 3D 2013
Windows 7 64-bit
Xeon E5-1620 v2 @ 3.70 GHz
Nvidia Quadro K4000
32.0 GB RAM
*Terry W. Dotson
Message 2 of 3 (491 Views)
Re: Scale X and Y, but not Z
12-01-2009 09:18 AM in reply to: ArchD
> not the z axis?
You can make a block of the source content, insert it at differing scale
factors, then explode. Note however that polylines will be exploded, it
does this because polyarc segments could become elliptical arcs.
We (DotSoft) also have an independent XYZ scale routine. If this is a
one time shot, email me the drawing to dotson [at] dotsoft [dot] com and
we'll scale it using that routine.
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
ArchD
Message 3 of 3 (491 Views)
12-01-2009 09:24 AM in reply to: ArchD
It is a one time shot, so the block option worked great. Thank you for that. Simple solution that I'm sure gets over looked all too often.
Archie Dodge
Civil 3D 2013
Windows 7 64-bit
Nvidia Quadro K4000
32.0 GB RAM
Post to the Community
New Post
Need installation help?
