AutoCAD 2010/2011/2012
Active Contributor
weedseed85
Message 1 of 8 (1,171 Views)
Rtext Diesel, cannoscale
1171 Views, 7 Replies
02-13-2013 06:58 AM
Dear autocad / lisp users,
Could somebody please help me.
I want to create a dynamic block that automaticly updates the viewport cannoscale a.k.a. Plotscale.
At the moment I / We have a dynamic block that contains a field for the Plotscale.
The only problem is, we have to fill it in ourselfs. so this means human errors or even blank fields.
Not so good.
Is there somebody who might knows a little bit of code to put in a RTEXT - Diesel block?
I will appreaciate anny help.
Thank you,
Michel
Try this it took me some time & help to get there, I think this is what J. Gerth is trying to tell you.
:smileyhappy:
JGerth
Message 2 of 8 (1,157 Views)
Re: Rtext Diesel, cannoscale
02-13-2013 09:43 AM in reply to: weedseed85
Why not use a FIELD, and use the Viewport object properties?
Active Contributor
weedseed85
Message 3 of 8 (1,142 Views)
02-13-2013 11:16 PM in reply to: JGerth
Thank you for your post.
I've tried the field command, but with no luck.
When I put in a FIELD, and choose plotscale, it does not
update when I change the VpScale. It just stays 1:1
or a big numer in modelspace.
I tried several times before but, no luck.
Valued Contributor
lesleys
Message 4 of 8 (1,129 Views)
02-14-2013 01:49 AM in reply to: weedseed85
:smileyhappy:
Active Contributor
weedseed85
Message 5 of 8 (1,117 Views)
02-14-2013 04:11 AM in reply to: lesleys
Thats exactly what I was looking for!
Truely perfect
Thank you so much!
Valued Contributor
lesleys
Message 6 of 8 (1,103 Views)
02-14-2013 05:18 AM in reply to: weedseed85
Nice to be able to pass on some of the help I have had over the years :smileyvery-happy:
craig.dunningham
Message 7 of 8 (909 Views)
03-11-2013 07:01 PM in reply to: lesleys
Do you know if RText can placed on 2 lines.
the code that is being used is on 1 line the problem is when there are a number of xrefs the code runs off the page
XREFS:$(xrefs,6,,/)
Should I put this in a new post?
Valued Contributor
lesleys
Message 8 of 8 (900 Views)
03-12-2013 02:27 AM in reply to: craig.dunningham
Diesel is not something I know about only what I have learnt from here.
Try this
$(xrefs,14)
I have just tried this in a drawing that has 2 xrefs & it listed them one below the other which is I think what you are looking for.
If that does not work you would probably be better as you suggest starting a new post with a different heading
:smileyhappy:
