Help please - Any viewport rotation other than a multiple of 90 results in distorted image. On the atttached pdf, the top vp is rotated 90 degrees (image looks the same as it does in model space - good), the bottom is rotated 135 (image is very light, almost a negative in places - bad).
I attached the geotiffs in dwg1 using mapinsert with no adjustment other than some fade, and am referencing dwg1 into dwg2. Plotting from dwg2.
I initially rotated the all the views with alignspace, when I noticed teh problem. I've since tried creating a new vp and just rotating/clipping it, same result.
Any ideas?
Thanks!
MRE
Solved by pendean. Go to Solution.
I guess I am in the wrong forum - I was thinking this one would be general. I'll post my question in Civil. Thanks & sorry
