AutoCAD Forum
Ribbons and Panels missing
7 REPLIES 7
Message 1 of 8
KLYPHY
898 Views, 7 Replies
My computer hiccupped and AutoCAD wouldn't run.
I eventually had to reinstall AutoCAD.
AutoCAD works, but there are no Ribbons.
Instead, the screen has this warning "The Ribbon does not have and tabs or panels loaded".
What's the next step?
7 REPLIES 7
Message 2 of 8
Patchy
in reply to: KLYPHY
Copy others' .CUI (all of them) overwrite yours and restart autocad.
Message 3 of 8
KLYPHY
in reply to: Patchy
On another computer, not linked to the other, AutoCAD has my named Workspace. Is that what you're referring to? If yes, where do I find it to copy to the other computer? If not, where do I find the ".cui" you mention?
Message 4 of 8
Patchy
in reply to: KLYPHY
If you use plain autocad, try the method:
(findfile "acad.cui")
and hit Enter, it will show the path where all the .CUI live
Grab all of .cui and replace the one that corrupted.
Message 5 of 8
pendean
in reply to: KLYPHY
Message 6 of 8
john.laidler
in reply to: pendean
Re-establish a workspace, this usually works in restoring the ribbons.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 7 of 8
KLYPHY
in reply to: KLYPHY
I check out your tips as soon as I get back to that computer. I'll let y'all know. Thanks.
Message 8 of 8
KLYPHY
in reply to: john.laidler
John had the answer. I went to the Workspace Control. As soon as I clicked on my Workspace name, everything returned to normal. Thanks.
”Boost
