AutoCAD 2010/2011/2012
Valued Mentor
Ian_Bryant
Message 1 of 8 (410 Views)
Ribbon = Screen Menu
410 Views, 7 Replies
06-14-2009 03:28 AM
My impression of the ribbon is that it is
the same as old screen menu but with
icons in place of text.
What annoys me is that the icons
change with every release of Autocad.
Look at the Match Properties icon.
Who who has used Autocd for a while,
has not switched the buttons on the status bar
to display text.
Distinguished Contributor
keithc03
Message 2 of 8 (410 Views)
Re: Ribbon = Screen Menu
06-15-2009 12:51 AM in reply to: Ian_Bryant
with you on the screen menu
new and improved=old and revamped .......(and Unecessary)
*Brian Harder
Message 3 of 8 (410 Views)
06-18-2009 03:15 PM in reply to: Ian_Bryant
Exactly.  I've been waiting for someone to
draw that comparison.
-Brian Harder
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
My impression of the ribbon is that it is the same as old screen menu but with
icons in place of text. What annoys me is that the icons change with every
release of Autocad. Look at the Match Properties icon. Who who has used Autocd
for a while, has not switched the buttons on the status bar to display
text.
Active Contributor
bdeshawn
Message 4 of 8 (330 Views)
07-01-2011 07:57 AM in reply to: Ian_Bryant
The screen menu was actually BETTER!  Because like you say, the text didn't change like the icons are changing, and it was very intuitive.  The big reason they were giving for the screen menu's demise it that it took up too much screen real estate.  Well, DUH!  HELLLOOOOO!  The ribbon takes up a WHOLE LOT MORE REAL ESTATE THAN THE SCREEN MENU EVER DID!  Who in the hell do they think they're kidding?  Thank  you Autodesk for allowing the RIBBONCLOSE and the MENUBAR commands.  That ribbon is just a bunch of glitzy crap that slows us down.  Lose it!
SteveAdams8888
Message 5 of 8 (316 Views)
07-03-2011 10:39 AM in reply to: bdeshawn
Yeh, I keep the Ribbon turned off and use ToolPalettes as my screen menu. I only use icons for my Block palettes, the rest are just text.
The ToolPalettes are great for their ease of editing, but if you pick an item too fast it drags it to a new position in the palette.
Steve
C3d 2010 (no SP)
Win7
dgorsman
Message 6 of 8 (300 Views)
07-04-2011 12:32 PM in reply to: bdeshawn
I'll throw out a contrary opnion.  I like the ribbon, and find it uses *less* space proportionally than the old screen menu due to the higher resolution monitors in use (and auto-hide, and three different minimized states, and horizontal/vertical placement, and folded panels, and...).  I find myself using very few if any toolbars or menus in AutoCAD anymore.  Even when I find myself missing a toolbar I'll tear off a panel or two to create floating uber-toolbars instead.  With the most common commands being aliased through PGP settings, I can keep panels with less common commands front and center for when I need them.
Interfaces change, icons change, work processes change.  Its the nature of the software beast and its only going to get worse as newer, faster, smaller hardware spurs more innovations.  If you can't adapt to a rapidly changing environment, you are definitely in the wrong business.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
keithc03
Message 7 of 8 (203 Views)
06-13-2012 06:46 AM in reply to: keithc03
Spoiler
NOTE to self
actually prefer the ribbon ......have done for some time now
There's no going back NEVER sometimes you just need to be pushed in the right direction
just hope they take the CLASSIC out like they did with screen menus
Now there's a thought A Clean AutoCAD with ALL the legacy obselete commands stripped out
A LEAN MEAN CAD MACHINE AUTOCAD 2014 !! or 2013.new
*Pro
nestly
Message 8 of 8 (199 Views)
06-13-2012 07:04 AM in reply to: keithc03
You could strip every single legacy command out of AutoCAD and it still wouldn't save enough resources to offset the overhead added just by AutoComplete, much less the Ribbon.
"Lean and Mean",  yeah, you can't get there by stuffing something full of fluff....
