AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 11
ribbon issues
322 Views, 10 Replies
12-07-2012 05:23 AM
MY ribbon has stopped changing with selections. It used to show hatch options when the hatch command was active, it no longer does this... It would also show hatch options if I selected a hatch with grips, and show other options for other entities if selected with grips, it no longer does this. What worng with it?
1,218 Kudos
Post 2 of 11
Re: ribbon issues
12-07-2012 05:30 AM in reply to: malform
verify two settings:
PICKFIRST
RIBBONCONTEXTSELECT
- alfred -
Alfred NESWADBA
Member
0 Kudos
Post 3 of 11
Re: ribbon issues
12-07-2012 05:47 AM in reply to: Alfred.NESWADBA
Thank you for your quick reply.
Unfortunately those settings didnt not fix the issue.
PICKFIRST was already on (1), and RIBBONCONTEXTSELECT was initially set to 1, I tried RIBBONCONTEXTSELECT on 0, 1, and 2 and it made no differance.
1,605 Kudos
Post 4 of 11
Re: ribbon issues
12-07-2012 06:08 AM in reply to: malform
What did you recently change or add (or delete) in AutoCAD 2012?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
0 Kudos
Post 5 of 11
Re: ribbon issues
12-07-2012 06:13 AM in reply to: pendean
The only thing I have altered recently is that I created my own workspae, and removed some pulldowns that I never use.  I dont know if this is the cause or not. But I do know if I switch to other workspaces, it still doesnt work like it should.
1,218 Kudos
Post 6 of 11
Re: ribbon issues
12-07-2012 08:05 AM in reply to: malform
And you are sure you have not modified any context-menu's also? After reading you have modified the CUIX that would be the first location to search.
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 7 of 11
Re: ribbon issues
12-07-2012 08:30 AM in reply to: malform
Can one of you guys help me with my post
Member
0 Kudos
Post 8 of 11
Re: ribbon issues
12-07-2012 09:31 AM in reply to: Alfred.NESWADBA
I can honestly say that I do not know if I inadvertanly modified any context menus. My only goal, and the only thing I did intentionally, was remove pulldowns.... How can I restore the menu to a pre-modified state?
1,605 Kudos
Post 9 of 11
Re: ribbon issues
12-08-2012 08:37 PM in reply to: malform
Member
0 Kudos
Post 10 of 11
Re: ribbon issues
12-10-2012 05:35 AM in reply to: pendean
Pendean, you are amazing!
Thank you so much, reset option worked.
Oddly, the pulldowns I removed are still gone, so I dont have to go back and tweak anything.
