Good afternoon,
I received a dwg. that if you want type new dimensions and notes it types in reverse or upside down with dimensions...
I have searched some setting to no avail ...my DWG. is ok this one is all crazy....
I send you the dwg. attached.... see for youself. (This DWG. is in metric)
Thank you
Alex B.
Solved by GrantsPirate. Go to Solution.
Set the UCS to World, set Plan to World. Maybe save the UCS before undoing.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
