AutoCAD 2010/2011/2012
Active Contributor
looking4phil
Message 1 of 6 (1,425 Views)
Reset default value on attributes within a block
1425 Views, 5 Replies
01-04-2012 07:29 AM
I have a titleblock with various attributes for title,dwg number, date, all that sort of thing. The drawing contains 43 layouts each with the titleblock in them and I want to show the default value of the attribute 'date', for example. Is there an easy way to do this. I would normally use find/replace if there was already text in the attribute concerened but there is currently no value. Hope this make sense to someone and can help!! Thanks.
Alfred.NESWADBA
Message 2 of 6 (1,413 Views)
Re: Reset default value on attributes within a block
01-04-2012 09:12 AM in reply to: looking4phil
three ideas:
  • create a default value for the attribute like "xxxDATExxx" so you can do something like replace (at least one time)
  • you can use fields within attribtutes, e.g. to show automatically the last plot-date or save-data (details >>>here<<<)
  • you don't define an attribute within the block definition, you use a text-object. So you can select one titleblock ==> blockedit ==> change the text to the date you want ==> close&save the blockdef ==> all insertions of this block will be updated. But be careful: if you have some software that works with informations coming from the titleblock they will not find a "date-attribute" any more!
HTH, - alfred -
Alfred NESWADBA
Active Member
tawadev
Message 3 of 6 (1,413 Views)
01-04-2012 09:18 AM in reply to: looking4phil
We can use sheetset for updating attribute in block.
Active Contributor
looking4phil
Message 4 of 6 (1,386 Views)
01-05-2012 01:06 AM in reply to: Alfred.NESWADBA
Am liking option 3 there, the most simple I guess. Never thought of that one. Thanks for your help.
Active Contributor
looking4phil
Message 5 of 6 (1,384 Views)
01-05-2012 01:29 AM in reply to: tawadev
Ah sheetsets, I am thinking I should probably start using this function. Will look into it. Cheers.
*Pro
murray-clack
Message 6 of 6 (1,371 Views)
01-06-2012 11:58 AM in reply to: looking4phil
What about using the GATTE command?
