AutoCAD Forum
Renaming the block, Error showing
2 REPLIES 2
Manicbala
243 Views, 2 Replies
Hi all,
When I renaming the old block, Error showing.
Error attached for your quick reference. Anyone kindly help.
Bala
Bala
2 REPLIES 2
pendean
in reply to: Manicbala
That name is already in use in your file: call it something else, PURGE your file, then try again. Or rename the old block to something else.
You can't fix this in the block editor.
Manicbala
in reply to: pendean
It's working. Thanks for your prompt response.
Bala
”Boost
