AutoCAD 2010/2011/2012
Distinguished Contributor
falconbird
Message 1 of 2 (149 Views)
Rename Associated Drawing File to Match Sheet Title
149 Views, 1 Replies
09-16-2011 06:26 AM
In the "Rename & Renumber Sheet" the rename drawing file to match is grayed out. How do I change it so I can uncheck it? Is there a globe way of unchecking all the files in the Sheet Set?
New Member
Btourville
Message 2 of 2 (31 Views)
Re: Rename Associated Drawing File to Match Sheet Title
07-16-2014 11:28 AM in reply to: falconbird
This option will be greyed out if you have the file open.  The OS is unable to rename the file if it is open.  Close the file first!  After that, (be sure another is open as you can't use sheet set dialogues without an open file) when engagin the "Rename and Renumber" dialogue and you will be able to uncheck the option.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
