We are using AutoCAD 2012. While working on it frequently an error message appears and automatically the program get closed.
The errors msg is :
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at 3f75825ch
Please Help..
Welcome to the Autodesk Forums!
A place to start:
Though I suspect that the Error is random generated characters and that the KB articles will not directly solve your query.
Can you try to pinpoint what you are doing when the error's occur?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
>> The error commonly occur when i try to zoom or pan
Two ideas (currently) to that:
1) search for another driver for your graphicscard
2) turn off the hardware acceleration and see it the problem continues to occur. (command _3DCONFIG ==> Manual Tune)
HTH, - alfred -
The display driver we installed is the origanl driver CD we got with Graphics Card.And the hardware accelerator also showing turned off..what to do..
Please Help...
That may not be the current one, search the www for an update of the driver.
BTW: what graphiccard do you use?
- alfred -
In many cases, as already said, this fatal error, is related to a not updated driver for your graphic card, please try the following:
Install the last Video Card Driver checking them from the following websites:
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Video Card manufacturer (for example Nvidia - ATI etc.)
PC/Laptop manufacturer (for example HPDell etc.)
hiii,
We tried everything,but no use. After that the system in which autocad installed is fully formatted.Os and Autocad reinstalled.Now one new error msg is coming.
"FATAL ERROR: Unhandled e0434352h Exception at fdd1a49dh"
What to do..?? Please Help
When does that error occur? Also when ZOOM or PAN is active? Or any other command or startup of AutoCAD, or same drawings, or loading same application, or ...?
- alfred -
