AutoCAD 2010/2011/2012
Active Contributor
dcoatsjr
Message 1 of 13 (490 Views)
Redefine Block Preview
490 Views, 12 Replies
11-29-2012 12:10 PM
I have a few blocks that I created and the picture in the Block Preview Window is small compaired to the other blocks on the drawing.  I can not figure out a way to redefine the block preview.  I have exploded the block. Purged and then redefined it.
Not sure what else to try.
Thanks for any help
*Expert Elite*
Alfred.NESWADBA
Message 2 of 13 (466 Views)
Re: Redefine Block Preview
11-30-2012 01:48 AM in reply to: dcoatsjr
try command _BLOCKICON (>>>details<<<).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
**Master
dmfrazier
Message 3 of 13 (455 Views)
11-30-2012 09:06 AM in reply to: dcoatsjr
Does it have to do with how close you are ZOOMed on the block objects when the block editor is closed (or when you define the block initially)?
Active Contributor
dcoatsjr
Message 4 of 13 (449 Views)
11-30-2012 09:32 AM in reply to: dmfrazier
I am not sure how it works.  I exploded the block and the purged it.  Then tried to recreate the block when zoomed in.. Looks the same ...  Not sure what to do.
**Master
dmfrazier
Message 5 of 13 (444 Views)
11-30-2012 10:55 AM in reply to: dcoatsjr
Here are two things to check/try:
1. Are there attributes in the block(s)?
2. What happens if you use REFEDIT instead of BEDIT to modify the block? (It looks like the block is not dynamic, so you don't really need to use BEDIT; REFEDIT should be sufficient.)
Active Contributor
dcoatsjr
Message 6 of 13 (410 Views)
12-03-2012 09:03 AM in reply to: dmfrazier
Active Contributor
dcoatsjr
Message 7 of 13 (409 Views)
12-03-2012 09:05 AM in reply to: dmfrazier
REFEDIT does not seem to affect the preview.
*Expert Elite*
Alfred.NESWADBA
Message 8 of 13 (399 Views)
12-03-2012 10:32 AM in reply to: dcoatsjr
there are some questions opend/not answered!
E.g. "is there an attribute defined within the blockdefinition" or "have you tried command _BLOCKICON"?
SCNR: Not to give feedback to suggestions made by others will sometime break this thread (like not interested in ideas presented).
- alfred -
Alfred NESWADBA
**Master
dmfrazier
Message 9 of 13 (381 Views)
12-03-2012 02:04 PM in reply to: Alfred.NESWADBA
Just curious: what does "SCNR" mean?
*Expert Elite*
Alfred.NESWADBA
Message 10 of 13 (376 Views)
12-03-2012 02:09 PM in reply to: dmfrazier
>>>click<<< :smileywink:
- alfred -
Alfred NESWADBA
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
