AutoCAD 2010/2011/2012
The_Caddie
Message 1 of 5 (1,286 Views)
Accepted Solution
Rectangle by size not coordinates?
1286 Views, 4 Replies
06-03-2012 11:49 PM
Dose anybody know why my AutoCAD now draws rectangles based upon coordinates and not by a given width and length as use to be?
I see what you mean but it had little effect on what I wanted, also thanks for the mention of the dimension sub- option within the rectangle command, If you view my lisp this is what Im utilizing to get my desired effect...
All up thanks for the help...
New Member
jenlei86
Message 2 of 5 (1,270 Views)
Re: Rectangle by size not coordinates?
06-04-2012 01:42 AM in reply to: The_Caddie
Well,you are supposed to reinstall CAD software,buddy! It's a suck problem!
The_Caddie
Message 3 of 5 (1,264 Views)
06-04-2012 02:17 AM in reply to: The_Caddie
so its a real problem? not a stray setting?
anyway i have just made my own lisp which basically dose the thing i want for now...
(defun C:MYRECTANGLE ()
;Get insertion point...
(setq MYRECTANGLEPOINT (getpoint "\nEnter a insertion point :"))
;Get direction point...
(setq MYRECTANGLEDIRECTION (getpoint "\nWhich direction? :"))
;Get width...
(setq MYRECTANGLEWIDTH (getstring "\nEnter a width: "))
;Get length...
(setq MYRECTANGLELENGTH (getstring "\nEnter a length: "))
;Placemant of actual rectangle...
(command "Rectangle" MYRECTANGLEPOINT "Dimensions" MYRECTANGLELENGTH MYRECTANGLEWIDTH MYRECTANGLEDIRECTION "")
;Closes command...
*Pro
nestly
Message 4 of 5 (1,259 Views)
06-04-2012 03:38 AM in reply to: The_Caddie
Perhaps Dynamic Input is set to Absolute coordinates rather than Relative coordinates?  (DYNPICOORDS)
Either way, the RECTANG command, should have an option for [D]imensions after picking the first corner.
The_Caddie
Message 5 of 5 (1,253 Views)
06-04-2012 05:39 AM in reply to: The_Caddie
Announcements
Need installation help?
