AutoCAD 2010/2011/2012
New Member
jwheeler
Message 1 of 6 (1,049 Views)
Recover user settings and profile after Changing domain
1049 Views, 5 Replies
03-29-2012 08:56 AM
We had to migrate from one domain to annother on our network. This meant that each user had to create a new profile.
Before we migrated I tried to back up the user data from the old user but once I am up an running agian all the AutoCad settings are no longer included. I understand you can export those while you are logged in and can see the macros etc. can you simply move the files that store that information (I can still access all the files from that user I just can't login as that user anymore)
any assitance would be greatly appreciated.
AutoCad 2011
Jeff
Product Support
Volker_C
Message 2 of 6 (1,003 Views)
Re: Recover user settings and profile after Changing domain
04-03-2012 07:21 AM in reply to: jwheeler
The settings for the user are in the registry but most of the user defined files for AutoCAD can be found in the following folders, some of which may be empty depending on what tools were used.
Windows 7 -->> C:\Users\<username>\AppData\Roaming\Autodesk\AutoCAD 2011\R18.1\enu
Windows XP -->> C:\Documents and Settings\<username>\Application Data\Autodesk\AutoCAD 2011\R18.1\enu
AssetLibrary
Data Links
LanguagePack
Materials
Migration
Plotters
Recent
Support <----------------------- Primary folder for user customization files (Menu files, Linetypes, acad.pgp). This folder also contains sub folders for tool palettes and Icons.
Windows 7 -->> C:\Users\<username>\AppData\Local\Autodesk\AutoCAD 2011\R18.1\enu
Windows XP -->> C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\AutoCAD 2011\R18.1\enu
LanguagePack
Support
Template
WebServices
I hope this helps.
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker Cocco
Support Specialist
Product Support
New Member
jwheeler
Message 3 of 6 (999 Views)
04-03-2012 10:43 AM in reply to: Volker_C
Thanks for the Reply I will let you know how it works.
Product Support
Volker_C
Message 4 of 6 (957 Views)
04-09-2012 03:26 PM in reply to: jwheeler
I just wanted to check if this had been resolved. If so, please let us know.
Cheers!
Volker
Volker Cocco
Support Specialist
Product Support
Product Support
Volker_C
Message 5 of 6 (938 Views)
04-12-2012 10:15 AM in reply to: Volker_C
I'm wanted to check if you had any feedback for us.
Volker
Volker Cocco
Support Specialist
Product Support
New Member
gfoulks
Message 6 of 6 (760 Views)
10-12-2012 01:08 PM in reply to: jwheeler
so what do we need to do to get the program to function when the user is logged into the new domain?
