AutoCAD 2010/2011/2012
Valued Contributor
tstorzuk
Message 1 of 7 (241 Views)
Recompiling menu file
241 Views, 6 Replies
08-18-2011 06:25 AM
A little help please,
Not sure if IT was messing around with stuff on my PC, but now every time I start up AutoCAD, it takes a very long time.....and there is a progress bar that says "Recompiling menu file <path>". What can I do to get the program back to how it was previously???
Thanks for the help.
Repair
Patchy
Message 2 of 7 (240 Views)
Re: Recompiling menu file
08-18-2011 06:27 AM in reply to: tstorzuk
Repair
Valued Contributor
tstorzuk
Message 3 of 7 (234 Views)
08-18-2011 07:08 AM in reply to: Patchy
Do you have a proceedure to follow? Something that will work properly?
Patchy
Message 4 of 7 (232 Views)
08-18-2011 07:11 AM in reply to: tstorzuk
Put in the disc, it will ask to repair or reinstall.
Valued Contributor
tstorzuk
Message 5 of 7 (226 Views)
08-18-2011 07:47 AM in reply to: Patchy
We had the programs installed on the network by IT......I guess I'll ask them.
Thanks for the help
azrdgldr
Message 6 of 7 (215 Views)
08-18-2011 08:12 AM in reply to: tstorzuk
Go to control panel, go add and remove programs, find autodesk product and select change to do a repair or re-install.
dgorsman
Message 7 of 7 (207 Views)
08-18-2011 09:00 AM in reply to: tstorzuk
Thats probably for the best.  There is no magic-wand solution to these sorts of problems, since they are highly dependant on where files are located, whether you use partial CUI(x) files loaded through the Enterprise or Main, whether you have third-party applications, whether they automatically add partial CUI(x)'s, and so on.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
