AutoCAD 2010/2011/2012
Active Contributor
TBOMS
Message 1 of 3 (1,483 Views)
Accepted Solution
"Unable To open this drawing. It contains incorrect or corrupted information"
1483 Views, 2 Replies
06-06-2012 11:23 AM
Hi
(Running AutoCAD 2010 on Win 7, Core i7, 8 GB RAM. All AutoCAD 2010 service packs are up-to-date)
I have a drawing file that keeps giving me this message when I try to open it :
"Unable to open this drawing.
It contains incorrect or or corrupted information.
The RECOVER command may be able to restore
undamaged material from this drawing."
When I recover the file I sometimes get a message that 1 error was fixed, sometimes no errors were detected. Either way, when I close it, and try re-opening (whether or not I SAVE it first), I get the same message. I have tried RECOVERALL, AUDIT, AECTOACAD (those AEC objects can be a problem) and tried changing the AutoCAD version it saves to (eg 2007). None of this works. I also discovered that if I WBLOCK the entire drawing it fixes it for ONE reopen, but becomes corrupted if I save it. This drawing is used as a 'template' (not a .dwt, just a "starting point") for other drawings, so the corruption is spreading..........
Any ideas? I am upgrading to a newr version of AutoCAD soon (hopefully that will fix it?), but this is really slowing down produciton in the meantime....
Cheers
TBOMS
Thanks, Alfred.
I'm afraid I reverted to my 'Caveman' cadding days; I just burst everything, exploded everything (multiple times), purged, and saw if it went away. It did :smileyhappy:
All I had to do then was re-build the drawing (while continually closing and re-opening), and that narrowed the problem down to a 'trouble' block, which I wiped from the face of the earth.
Another day, another AutoCAD mystery solved
TBOMS
*Expert Elite*
Alfred.NESWADBA
Message 2 of 3 (1,480 Views)
Re: "Unable To open this drawing. It contains incorrect or corrupted inform
06-06-2012 12:41 PM in reply to: TBOMS
Have you tried to save the drawing to a different drive? So e.g. if you saved it to network then try to save it to your local drive or to an usb-device.
You should also check what antivirus-software (or defender, or antiXXX) you are running, maybe disabling them while testing.
One additional try: create a new drawing (real new from an AutoCAD template) and insert your "defect" drawing into it (explode it while inserting), then save this drawing as your new prepared base-drawing.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Contributor
TBOMS
Message 3 of 3 (1,469 Views)
06-06-2012 02:30 PM in reply to: Alfred.NESWADBA
Thanks, Alfred.
TBOMS
Post to the Community
New Post
Need installation help?
