AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 8
Purging Unused Blocks
4092 Views, 7 Replies
04-02-2012 12:37 PM
Situation:
I’m currently cleaning up an old file that is rather large. (so large I cant xref anything with out AutoCAD crashing)
Problem:
There are way too many “blocks” in the file, about 700 in all. Of these 700, more then 600 of them aren’t even being used anymore.
Question:
Is there a way to purge out unused blocks?
Thanks for the help.
Yes, just use the PURGE command.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
Joe,
Type PURGE, check the Purge Nested Items option and uncheck Confirm each item to be purged options in the Purge dialog box, then click Purge All.
Jon
Also,
Use "-PURGE" and "R" for regapps - at least with C3D the unused / unnecessary regapps can really bloat a drawing - such as from 600KB to 3MB....
Best of Luck!
And don't be afraid to run it more than once.  The first time PURGE can reveal nested blocks but not remove them.  A second, or subsequent PURGE, will be needed to get rid of them.
Dave.
62 Kudos
Post 2 of 8
Re: Purging Unused Blocks
04-02-2012 01:03 PM in reply to: JoeMin
Valued Mentor
8 Kudos
Post 3 of 8
04-02-2012 01:05 PM in reply to: JoeMin
Joe,
Jon
Jon
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
Distinguished Mentor
35 Kudos
Post 4 of 8
04-02-2012 01:35 PM in reply to: JoeMin
Also,
Best of Luck!
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
127 Kudos
Post 5 of 8
04-02-2012 04:01 PM in reply to: vladimir.michl
Dave.
Dave Hein, P.E.
Active Member
0 Kudos
Post 6 of 8
04-03-2012 05:06 AM in reply to: JoeMin
Ya, im realy rusty with AutoCAD, compleatly forgot about the purge command. i did it a few times, made most of the files go from 6,700 KB to arou 1,000 to 175 KB.
thanks for the help guys.
Active Member
0 Kudos
Post 7 of 8
10-15-2014 10:52 PM in reply to: JoeMin
I have sthe same problem. I cannot purge block name. That have no object inside. Please see my attached file
Active Member
0 Kudos
Post 8 of 8
10-16-2014 04:13 AM in reply to: sleepy86
