AutoCAD Forum
Purging Project wide Utilities
13 REPLIES 13
Message 1 of 14
davidpaik
1280 Views, 13 Replies
Every time i run a project wide purge all blocks routine in Acad 12, it doesn't purge anything at all.  Only when i go to each individual page and purge all.
I would like to remove any unused blocks/layers......
Is there a fix or a 3rd party app?
13 REPLIES 13
Message 2 of 14
steve216586
in reply to: davidpaik
When you say "individual page" do you mean each individual tab layout or each individual file?
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 3 of 14
davidpaik
in reply to: steve216586
individual drawing
Message 4 of 14
rkmcswain
What is a "project wide purge all blocks routine"?
Is this 3rd party or are you working in a vertical app?
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 14
jggerth
Look into using eTransmit. there's an option in the setttings for that tool to Purge drawings as they are packaged up.
hope you mean Acad 2012, not R12 Smiley Wink
Message 6 of 14
steve216586
Try the attached lisp. It's not mine but it may be what you are looking for.
Message 7 of 14
davidpaik
in reply to: jggerth
yes 2012...
where is the option to set the purge?
Message 8 of 14
steve216586
Open a drawing. Load the lisp. Type PURGED on command line. It will ask you for a directory. Copy and paste the directory from Windows Explorer. Then it will purge the drawings in that folder.
Message 9 of 14
jggerth
ETRANSMIT command, add wahtever files you want, then use the Transmittal Setups... button on the right,
either Modify an existing one, or create a new one to modify.  Purge is a check box on the left of that dialog.
Message 10 of 14
davidpaik
this creates a zip file, now what..... not sure what exactly that accomplished
it just archives the files.....
Sorry if i sound like i am tottaly confused
Message 11 of 14
davidpaik
I think back in R2010 autocad electrical , i made a change to the "next page drawing" macro... it would pu 5 times and then zoom extent save and then change the page.  But in 2012 i cannot do the purge addition because of a tab box that would appear.  Is there a work around for this?
Message 12 of 14
steve216586
I use a macro for purging:
c^c^-PU;ALL;;N;Z;E;SAVE;
for blocks only, as you asked:
c^c^-PU;B;;N;Z;E;SAVE;
-PU keeps the dialog box from appearing, as compared with simply PU.
Message 13 of 14
davidpaik
thanks!!!!!!!!!!!!!!!!!!!!!!!
that works
Message 14 of 14
jggerth
that give you a zip file full of purged drawings.  just unzip over the originals
”Boost
