AutoCAD 2010/2011/2012
*greg oprzadek
Message 1 of 4 (790 Views)
Publishing problems-DSD file message, model tab included in published list
790 Views, 3 Replies
03-30-2009 02:48 PM
If I open a drawing created in 2009 and try to publish it in 2010, DSD file
message pops saying about unsaved changes (see attached). Since I don't use
sheet sets, I do not have any use for DSD file. Is there a way to disable
it?
In 2009 it was simple not to include model tab while publishing. Where is
this option in 2010? I don't want to remove model tab from the list every
time I publish drawings.
TIA
grego
Greg Oprzadek
Project Engineer
O.B. Williams Co.
www.obwilliams.com
*MWN
Message 2 of 4 (790 Views)
Re: Publishing problems-DSD file message, model tab included in published list
03-30-2009 03:52 PM in reply to: *greg oprzadek
In the Publish dialog if you right click in the sheet list you can uncheck,
Include Model Sheets.
-mike
"greg oprzadek" <<> wrote in message news:6152249@discussion.autodesk.com...
it?
TIA
grego
Greg Oprzadek
Project Engineer
O.B. Williams Co.
www.obwilliams.com
*greg oprzadek
Message 3 of 4 (790 Views)
03-30-2009 05:02 PM in reply to: *greg oprzadek
Thank you Mike! Now is just the pesky DSD file message.
grego
wrote in message news:6152277@discussion.autodesk.com...
-mike
it?
TIA
grego
Greg Oprzadek
Project Engineer
O.B. Williams Co.
www.obwilliams.com
Member
Altex
Message 4 of 4 (413 Views)
06-13-2012 12:18 PM in reply to: *greg oprzadek
I just ran into this same issue myself and after hours of playing around I found this site that explains how to fix it.  Mine is back to working how it's supposed to after using this fix.
http://adndevblog.typepad.com/autocad/2012/05/turn-off-the-automatic-save-of-dsd-files-when-running-...
Announcements
Need installation help?
