AutoCAD Forum
Properties Tab/Ribbon not working
1 REPLY 1
joetully20
683 Views, 1 Reply
Hi all!
I am having issues changing the properties of a line/object through the properties tab and ribbon.
I havent had a problem before, but when i select something and try to change colour/line type etc, nothing happens. The command line just reverts back to "command:"
If I use the Ctrl+1 pop up, i can change properties. Though this solves the problem, it isn't as convenient as having the tab or ribbon in the border
No layers are locked/frozen etc, and all i can think of is that i've accidentally typed in a command that has altered something. I am having the problem in all cad drawings. And the problem doesnt occur when i use a colleagues computer.
I am only 6 months into using Autocad, so if this is a simple problem, apologies 😛
Joe
1 REPLY 1
joetully20
in reply to: joetully20
Sorry, it's been solved. It was just the 'pickfirst' settings!!
”Boost
