AutoCAD 2010/2011/2012
nb
Active Member
nb
Message 1 of 11 (2,701 Views)
Properties panel missing
2701 Views, 10 Replies
09-23-2010 04:19 AM
I have no properties panel within the home tab, with the transparency panel in its place.  Can anyone guide me in the right direction to reinstate the properties panel.
Thank you
Valued Mentor
stevenelliott3894
Message 2 of 11 (2,694 Views)
Re: Properties panel missing
09-23-2010 05:04 AM in reply to: nb
Well, you can get ithe panel to appear with Control + 1.
Steven Elliott
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
nb
Active Member
nb
Message 3 of 11 (2,688 Views)
09-23-2010 05:47 AM in reply to: stevenelliott3894
Thanks for this but it is the properties panel within the ribbon that I am missing?
Valued Mentor
stevenelliott3894
Message 4 of 11 (2,686 Views)
09-23-2010 05:49 AM in reply to: nb
Sorry, I don't use the ribbon at all. I just figured if you needed the Properties Box to show, I'd get you there.
Steven Elliott
nb
Active Member
nb
Message 5 of 11 (2,681 Views)
09-23-2010 05:55 AM in reply to: stevenelliott3894
My main issue is changing the line weight on elements like walls, where an option is not provided in the properties palette when selected.
Nigel
Valued Mentor
stevenelliott3894
Message 6 of 11 (2,679 Views)
09-23-2010 05:57 AM in reply to: nb
I generally use the Quick Properties, which can be customized as to what it shows for each entity type.
Steven Elliott
*Pro
nestly
Message 7 of 11 (2,668 Views)
09-23-2010 07:00 AM in reply to: nb
Go into your CUI by either selecting Customize, or by typing CUI at the command line
On the Customize Tab, click + to expand the Ribbon menu
Click + to expand "Tabs"
Click + to expand "Panels"
Scroll down through the panels list and right click on "Home - Properties" and copy it.
Go back up to the "Tabs" menu and right click on "2D Home" and click paste.
Click + to expand the "2D Home" tab and you should now see Properties on the Ribbon "Home" tab along with Draw, Modify, Annotation etc.  (You can move the "Properties" panel up the list if you want it to be closer to the left side of the Ribbon)
Click Apply & Close
Once you're satisfied, be sure you save your workspace.
nb
Active Member
nb
Message 8 of 11 (2,640 Views)
09-23-2010 08:47 AM in reply to: nestly
Thanks for this but I do not have 'Home - Properties' only properties which is empty with no buttons.  I am using 'aca_uk.cuix?
Nigel
*Pro
nestly
Message 9 of 11 (2,633 Views)
09-23-2010 10:19 AM in reply to: nb
 Scroll down to the bottom of the top left CUI customization window and see if ACAD is already loaded as a partial customization file.  If it's there, you can copy the panel from there.
Do you have a CAD manager that customizes your CUI?  Unless someone removed/replaced it, you should be able to load acad.cuix as a partial customization file and have access all the original tabs, panels, menus, toolbars etc.
edwinprakoso
Message 10 of 11 (2,598 Views)
09-23-2010 07:59 PM in reply to: nb
Just wondering, have you check the PICKFIRST variable? Change it to 1 if yours is 0.
Edwin
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
