AutoCAD Forum
Prompt vindow on dynamic blocks
2 REPLIES 2
danhaavard
287 Views, 2 Replies
Hello, I am using Autocad LT 2010, and am trying to make a library of dynamic blocks to make our drafting go faster.
I am now using Dynamic Blocks, wich I like to have several views and sizes on, for an example a cylinder, with side view, top view and so on, and different diameters.
I have two main problems with making these, the first one was that I found it hard to use `Attribute Definition` pared up with block properties table, when I had several sizes, the table seems to be locked to on view, so I cant change all views.
The other problem I found is that I cant get the normal `prompt window`to come, when I insert  the block into a drawing, would like a prompt window, where I can choose wich parameters I want to be changeble.
Have attached a simple drawing of a nipple, its with lookup tables on each view, but no prompt window.
Tags (1)
2 REPLIES 2
pendean
in reply to: danhaavard
There is a dedicated forum for DynBlocks: http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
danhaavard
I didn't know that, thanks for the info
”Boost
