AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 4
Accepted Solution
Problem with SSGET when filtering string content
401 Views, 3 Replies
12-12-2012 04:59 AM
Hi all,
I don;t know what the *** happen with this piece of code, I have checked it a million of times and seems to be well done. I'm trying to filter a previous selection and select Text or Mtext objects that are in the layer COTREF, and that contain the strings "%%c" AND "L" at the same time. The problem is that the code it's not selecting objects with the "L" included.
Here's the code:
(setq grupo1 (ssget "" '((0 . "TEXT,MTEXT")(8 . "COTREF")(-4 . "<AND")(1 . "*%%c*")(1 . "*L*")(-4 . "AND>"))))
The most unreasonable thing it's that I have 2 text objects exactly the same and when using this filter codes just one object it's selected (cyan cloud), check included DWG file.
Any idea ?????
I'v been searching abouit it and seems some persons are having problems with ssget filters in the newer versions of AutoCAD, I'm using 2012. I'm also suspecting fo the caracter "%" which could be working as a wild-card, but as far as I know it is not.
Thanks for any help about it.
This selects some:
(command "change" (ssget '((0 . "TEXT,MTEXT")(8 . "COTREF")(-4 . "<AND")(1 . "*%%c*")(1 . "*L*")(-4 . "AND>")))"" "p" "c" "1" "")
This selects the rest:
(command "change" (ssget '((0 . "TEXT,MTEXT")(8 . "COTREF")(-4 . "<AND")(1 . "*%%C*")(1 . "*L*")(-4 . "AND>")))"" "p" "c" "1" "")
Can you spot the difference?
*Expert Elite*
190 Kudos
Post 2 of 4
Re: Problem with SSGET when filtering string content
12-12-2012 10:55 AM in reply to: vatorres
This selects some:
New Member
0 Kudos
Post 3 of 4
12-13-2012 01:55 AM in reply to: dbroad
Man, you are a genious !!!!
Thanks so much for take your time and help me, so simple now that I understand it ...
Regards
*Expert Elite*
190 Kudos
Post 4 of 4
12-13-2012 06:51 AM in reply to: vatorres
You're welcome.  Be sure to mark the post that worked with "accept solution"
Post to the Community
New Post
