recently I started using AutoCAD 2012 and I ran into one problem which I didn't encounter before.
The problem is that when I try to paste objects from another drawing (through clipboard - usually another instance of AutoCAD) I can't paste them in some drawings only.
The following things happen:
-Autocad behaves normally like when I usually paste objects except there is nothing inserted.
-When I save the drawing after unsuccesful insert, even if I canceled inserting, drawing size increases dramatically (for about 2-4MB).
-If I open new drawing, I can insert objects there.
-Also when I copy to clipboard, autocad takes a lot of time even if it is only few lines.
I tryed these thing to fix issue:
-I checked if there are any layers turned off.
-I tryed to copy with COPYBASE
-I restarted autocad (sometimes it helps but only for some moments or for one insert).
-I did PURGE and AUDIT
-I tried to copy paste in same instance of AutoCAD but that didn't help.
Oh and I'm usualy using t least 2 instances of AutoCAD (I hope that is not the problem).
Thanks in advance for your help.
Regards
I'm using two instances of AutoCAD because I have two monitors and I work in both simultaneously.
BTW I was using AutoCAD 2011 and 2010 the same way and I didn't have any such problems.
Thawing/turning, zooming and regening don't fix the problem.
It depends, I can copy items to some drawings but not to others regardless of the session. It's more like AutoCAD suddenly decides to stop me from inserting objects on some drawings from some point on.
The objects are definetly in clipboard because if I open new drawing I can paste them there.
Maybe the problem is with AEC or something because the drawing is pretty complex and many users worked on it but still I was working on the same drawing with AutoCAD 2011 version and I didn't have such problems.
Currently my solution is that I copy the drawing to new drawing, save it and then insert whatever I want to insert. The problem is that I must do (repeat) this for every inserting process. Strange is that purge, audit and saving drawing under other name doesn't work (I still can't insert), I must copy it.
Here is one more thing to check. When copying with a base point from one drawing to another, I find it best to have both UCS set to World.
Well, when you run into issues, just usese the old 'WBlock and Insert' workflow instead of copying and pasting.
