AutoCAD 2010/2011/2012
Valued Contributor
kevms
Message 1 of 8 (368 Views)
problem with entering surveyor units
368 Views, 7 Replies
08-30-2011 05:51 PM
Hello All
I haven't done a site plan in a very long time and after doing some reading thru some help files and other websites, I am having trouble entering coordinates for a site plan. As you will see in the attached jpg, I am getting an error while trying to enter the following and other coordinates. My units is set to surveyor units (the unusually large command line is just show you what I have tried to enter. north is to the top of the screen.)
what I did
Line: pick point (enter)
Specify next point or [Undo]: @34.13<s179d57'00"w
Point or option keyword required.
cancelled command.
I am not sure what I am doing wrong, but if I remove the "@" symbol and "n" or "e" directions, the lines go what ever which way.
Can anyone help me.
Thanks in advance
Kevin
Kevin
Using Revit Structure 2012, 2013, 2014
I think I am getting the hang of this revit stuff
*Expert Elite*
Patchy
Message 2 of 8 (362 Views)
Re: problem with entering surveyor units
08-30-2011 06:15 PM in reply to: kevms
Why you keyed in more than 90 degrees ?????????????????
Never gonna work.
Valued Contributor
kevms
Message 3 of 8 (359 Views)
08-30-2011 06:25 PM in reply to: Patchy
so what do i do?
Kevin
*Expert Elite*
Patchy
Message 4 of 8 (352 Views)
08-30-2011 07:24 PM in reply to: kevms
Where did the descriptions come from? Are you sure this isn't azimuth?
Valued Contributor
kevms
Message 5 of 8 (344 Views)
08-30-2011 08:08 PM in reply to: Patchy
A pdf file was sent to me by our PM, who received it from the developer. I am not sure if the info is azimuth as you mentioned. how can I tell?
On a separate note, I was given the I believe the following info
A=21.55 (This is arc length correct)
R=13.72 (this is obvious radius)
Thanks for you help so far.
Kevin
Kevin
*Expert Elite*
Patchy
Message 6 of 8 (342 Views)
08-30-2011 08:20 PM in reply to: kevms
Azimuth is measurement from assumed north, measure clockwise in degrees and no direction given such as NW, NE,SW,SE.
No surveyor would give you direction more than 90 degrees in one quadrant.
Valued Contributor
kevms
Message 7 of 8 (338 Views)
08-30-2011 08:36 PM in reply to: Patchy
okay i think i understand,
well some of the bearing measurements that I have been given are shown below. (no direction info was given) i know it is hard to do a site plan without the direction, but this is the only information that was available from what I've been told.
179d57'00"
179d'54'50"
I see what i can do
thanks
Kevin
*Expert Elite*
Patchy
Message 8 of 8 (329 Views)
08-30-2011 09:00 PM in reply to: kevms
Draw a vertical line, then rotate from the south end of the line to that degrees (use negative degrees, because autocad works that way)
Need installation help?
