AutoCAD 2010/2011/2012
Active Member
hamadsaeed
Message 1 of 12 (342 Views)
problem with Autocad 2010 variables
342 Views, 11 Replies
04-22-2013 01:53 AM
the problem I was facing (and still facing) was that I use my mouse middle button (scroll) as pan when clicked, But it poped out menu for snap overrides, then I resolved this issue by MBUTTONPAN variable by setting its value to 1. Now when I start a new file or a new session it reverts back to snap override menu and I have to again use variable. The changes I am making are not lasting more then a drawing. Can any one tell me what's causing this and how can I resolve this. Once I made a change in variable it should be permanent unit I change it again, but it is not. So does any one  have any solutions. I have also tried profile for this case, but same results.
Alfred.NESWADBA
Message 2 of 12 (328 Views)
Re: problem with Autocad 2010 variables
04-22-2013 02:42 AM in reply to: hamadsaeed
Either you don't have enough permissions to overwrite the value in the registry or there might be a lisp that turns MBUTTONPAN back to the old value. As you wrote that this happend with every opening of a drawing look to the files
ACADDOC.LSP
ACADDOC2010.LSP (which should never be modified, but this warning is often ignored)
Or you have an application that does that, in that case you have to ask the vendor of this tool/application.
- alfred -
Alfred NESWADBA
Active Member
hamadsaeed
Message 3 of 12 (324 Views)
04-22-2013 02:54 AM in reply to: Alfred.NESWADBA
Thnak you alred for the reply. But what is the solution or do I have to ask the vendor for this.
Alfred.NESWADBA
Message 4 of 12 (313 Views)
04-22-2013 03:03 AM in reply to: hamadsaeed
If you have a tool or an application on top of AutoCAD you should ask the vendor of this tool/application ... yes. He might have a reason to set this variable.
The other option is to search for the two files I mentioned. That files control what happens when a DWG is opened or a new DWG is created. They contain LISP-functions that are started then automatically. And this might be used to reset MBUTTONPAN to 0 every time a DWG is loaded .... so search for that files, open them in any texteditor like notepad and look if you find the word "MBUTTONPAN" in them ==> if yes you have the chance to remove the automatic setting now. But to do that you must have LISP knowledge (a little bit) to know what part exactly is to remove, commonly the while line, but therefor we should see the file instead of doing guessing. At least, if "MBUTTONPAN" is found in any of that two files there must be someone that has that modification done (this is not the default). Try to find that guy.
HTH, - alfred -
Alfred NESWADBA
hmsilva
Message 5 of 12 (307 Views)
04-22-2013 03:13 AM in reply to: hamadsaeed
hamadsaeed,
in addition to what Alfred already said, if you have a acad.lsp, see also in that file.
hope that helps
Henrique
Alfred.NESWADBA
Message 6 of 12 (299 Views)
04-22-2013 03:30 AM in reply to: hmsilva
The op stated that this happens every time a drawing is opened. ACAD.LSP is only started once when AutoCAD is started, but not with every new DWG or open DWG.
Anyway, for other readers in the future it's a good addition! :smileywink:
- alfred -
Alfred NESWADBA
hmsilva
Message 7 of 12 (295 Views)
04-22-2013 03:35 AM in reply to: Alfred.NESWADBA
- alfred -
not quite...
Cheers
Henrique
Alfred.NESWADBA
Message 8 of 12 (291 Views)
04-22-2013 03:38 AM in reply to: hmsilva
Yep, you're right, my appologize!
- alfred -
Alfred NESWADBA
hmsilva
Message 9 of 12 (286 Views)
04-22-2013 03:45 AM in reply to: Alfred.NESWADBA
Alfred,
apologize, it's not necessary, all have lapses :smileywink:
Cheers
Henrique
Active Member
hamadsaeed
Message 10 of 12 (182 Views)
04-22-2013 10:11 PM in reply to: hamadsaeed
Thanks for the tips but none of them resolved the issue infact any changes I make to any variable is just applied in the current file (the file I am working on) and when I open a new drawing or a previous drawing to edit the changes are undone.
never the less I look for any other possible solution if any one has in the mean while I'll try to contact the vendor also.
