AutoCAD 2010/2011/2012
Member
bigjsheets
Message 1 of 4 (7,851 Views)
Problem binding xref (proxy object)
7851 Views, 3 Replies
08-10-2009 09:42 AM
I am trying to bind a floor plan into a drawing an I get the error: at least one of the specified xrefs failed to bind due to a problem with a proxy object. The floor plan was created by an outside company and we did the electrical engineering. Now that our files are due to the customer, i have to get our drawings to bind. Any suggestions on a solutin and what causes this? Thanks guys
Active Contributor
bsilewicz
Message 2 of 4 (7,851 Views)
Re: Problem binding xref (proxy object)
08-10-2009 11:31 AM in reply to: bigjsheets
I would open up the XREF and run an audit on that drawing and then I would do a saveas. After that I would try to bind the XREF.
markdoel
Message 3 of 4 (7,851 Views)
08-10-2009 09:23 PM in reply to: bigjsheets
run a recover all to see if that helps.......alternatively don't bind, simply e transmit the drawing files and relevant xref data.
these days AutoCAD can reference many different file formats i.e. images, dgn, pdf etc...none of which will bind so continuing to use such a dated workflow is going to become more and more problematic.
New Member
Elisa_fau
Message 4 of 4 (5,305 Views)
05-17-2013 10:40 AM in reply to: bigjsheets
Had the same problem. I just selected all the drawing I wanted to copy and used the EXPLODE tool. Then I was able to copybase or put this drawing as an xref at another drawing and bind it. It works with the EXPLODE tool because it breaks the proxy objects that don't allow the command copybase or xref.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
