AutoCAD 2010/2011/2012
Distinguished Contributor
7 Kudos
Post 1 of 6
Probelm with deleting old customized menu using CUI Editor
491 Views, 5 Replies
02-09-2012 12:18 PM
Trying to remove old customized menu from AutoCAD 2010. Open CUI Editor, right click on old menu file (*.cui) , but DELETE has been grayed out.
Any suggestions
*Expert Elite*
1,588 Kudos
Post 2 of 6
Re: Probelm with deleting old customized menu using CUI Editor
02-09-2012 12:25 PM in reply to: lgabriel
CUIUNLOAD command.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
7 Kudos
Post 3 of 6
02-09-2012 12:32 PM in reply to: pendean
CUIUNLOAD is how I got to the CUI Editor. When I right click on the menu I want to delete, the DELETE is grayed out.
Is there a different way to use CUIUNLOAD?
*Expert Elite*
1,588 Kudos
Post 4 of 6
02-09-2012 12:44 PM in reply to: lgabriel
CUIUNLOAD brings up a separate pop-up, not the CUI POP-UP, and it has a simple structure. It also only has an UNLOAD button, no delete button.
It has always looked like that, even in R2010: if you got the CUI window instead, someone at your end doesn't want you to do what you are doing. Type it at the command line, place a period in front of the name to invoke the core command:
.CUIUNLOAD
7 Kudos
Post 5 of 6
02-09-2012 12:58 PM in reply to: pendean
Once I unload the menu file, it is gone. However when I close AutoCAD, and reopen, the menu is reloaded.  Since this is a custom menu just for me and not the rest of the department, it is not loaded during the normal starup routine for AutoCAD. I also checked my acad2010.lsp and ACADUSER.lsp and neither program reloads and menus.
Also once I unload the custom menu, and type CUI, the custom menu is still display and when I click on it the DELETE key is grayed out.
What I want to happen is for the unload to be permanent.
*Expert Elite*
1,588 Kudos
Post 6 of 6
02-09-2012 02:21 PM in reply to: lgabriel
Close AutoCAD.
Start Windows Explorer, find the CUIx file and it's MNR extension namesake file and delete them. Search for other locations for these two files on your PC, and delete them.
Now start AutoCAD: it should start complaining and let you know where it's loading from and where the entry that is loading it is seeking it.
Post to the Community
New Post
