AutoCAD Forum
Printing an exported PDF underlay
4 REPLIES 4
627 Views, 4 Replies
I am using a PDF underlay in AutoCad 12 - I added things to the drawing and saved. It prints fine when I use AutoCad, but after I export to PDF to send to my client, it only prints and displays the new items I added, not the underlay.
Help...
4 REPLIES 4
Alfred.NESWADBA
Don't use command _EXPORTPDF,try instead command _PLOT and select "DWG to PDF" as plotter.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Just tried that and it still only displays and prints the AutoCAD portion,
not the underlay.
dgorsman
The PDF underlay is a drawing entity just like an image or XREF, so ensure its not on Layer 0, Defpoints, or a layer that is set to not plot.  You may also want to check plot settings as I'm uncertain how PDF behaves with any of the 3D visual styles.
in reply to: dgorsman
Thank You.
”Boost
