AutoCAD Forum
Possible to run a script on block insert?
2 REPLIES 2
prog0101
297 Views, 2 Replies
Is there any way to attach a script (.NET, LISP, SCR, etc) to a dynamic block, so that whenever the dynamic block is inserted the script will run?  AutoCAD 2011.
2 REPLIES 2
jggerth1
in reply to: prog0101
not attached to the block, but a Reactor ought to get you started.  check in the customization autolisp forum
prog0101
in reply to: jggerth1
Thanks!
”Boost
