AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 4
popup height/depth/angle/etc. box is missing
443 Views, 3 Replies
03-20-2012 12:47 PM
When i used to draw a rectangle, circle, line, etc- a box (or several) boxes popped up after i clicked the first point. These let me enter the distance then hit the tab button and go to a second box to enter height or angle depending on what i was drawing.  There was also some popups that showed up when clicking the chamfer or fillet buttons but now those are all gone.  When i input numbers, it goes to the command bar.
I didnt change anything and am frustrated.  How can i get those small popup windows to reappear in my modelspace?
Thanks, in advance.
look up dynamic input in help
Active Member
0 Kudos
Post 2 of 4
Re: popup height/depth/angle/etc. box is missing
03-22-2012 06:36 AM in reply to: uncisbest
bump.
312 Kudos
Post 3 of 4
03-22-2012 10:08 AM in reply to: uncisbest
Active Member
0 Kudos
Post 4 of 4
03-22-2012 10:21 AM in reply to: JGerth
thanks for your help.  Somehow my DYNMODE value was set to -3 instead of 3.  when i switched it back, everything worked as it used to.
