I would love for my 2011 and 2013 to work the same as my 2008 does.
In 2008, when I grab a grip and stretch it with either ortho or polar turned on, I get a little tooltip beside the crosshairs. All it says is the distance and the angle, and whether it is Ortho or Polar. For example, if I stretch to the left with ortho on, it may say
Ortho: 16.55 < 180°
Or if I stretch up and to the right with Polar on, it will say
Polar: 16.55 < 45°
I really, really really want this back! This is not dynamic input, I hate all that ridiculous clutter around my crosshairs. But this little info box is absolutely invaluable!
I have checked the Tooltip setting (on in all versions), And I've been playing with all the Dynamic Input settings, but I can't get it to work. The odd part is that 2011 was working until about a week ago. I'm not sure if 2013 was or not.
Thanks everyone.
Mark Green
Working on Civil 3D in Canada
Solved by steve216586. Go to Solution.
Solved by nestly2. Go to Solution.
If "2011 was working until about a week ago", it sounds like something has changed that you are not aware of or didn't initiate, within the program. Do you have 2008, 2011, & 2013 loaded on the same computer? This may be your problem if true. Definately not a good idea to keep old versions after an upgrade, especially when they aren't all in the same 3 year development window.
Mark Green
I didn't realize each year is completely incompatible until I read it myself. You have my condolences.
I hope someone in the C3D field can help.
It almost makes sense to have your computer partitioned to support each one individually.
Mark Green
Mark Green
When you grab a grip in the newer versions, there are at least 4 things that can be displayed at the cursor.
- Ortho/Polar tracking
- OSnap tracking
- Dynamic Input
- Dimensional Input
if you disable the last 3, all you'll get is what you described in the first post.
Try OPTIONS - Drafting Tab and make sure the box has a check for "Display Autotrack Tool Tip". I turned mine off and it disappeared when Move, Copy, Draw line, etc. Back on and everything normal.
see attached
