AutoCAD Forum
Point label size
3 REPLIES 3
asloat
892 Views, 3 Replies
Point label size
I have a user with AutoCAD 2012, not Civil3D. Is there a way for this user to change the size of point labels in this program or is this a feature the program does not support and he needs to do it with point label styles in Civil3D?
3 REPLIES 3
Patchy
in reply to: asloat
Plain autocad cannot change point label styles of C3D.
asloat
in reply to: Patchy
Thank you
braudpat
in reply to: asloat
Hello from France
If your "classic" AutoCAD Points are on a different Layers or have a forced Color, you could easily select them !?
So with a Lisp/VLisp routine which draws Blocks on the selected Points, you will get differents "Styles of Points"  ( = Different Blocks )
Please find attached this Lisp Routine P2B , that I use sometimes for this purpose ... Sorry I don't know the Author !
Loading with : APPLOAD
Run with : P2B
( Blocks must already exist in the current drawing )
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
