AutoCAD 2010/2011/2012
New Member
lconroy
Message 1 of 4 (2,401 Views)
plotting very slow
2401 Views, 3 Replies
09-19-2011 08:02 AM
We currently have 4 licences for AutoCAD 2012 and once it was installed it takes a really long time to plot and the hour glass just keeps flipping. What can i do to resolve this problem?
Product Support
luconceicao
Message 2 of 4 (2,384 Views)
Re: plotting very slow
09-20-2011 09:25 AM in reply to: lconroy
Are you using the Plot command or Publish?
Does the Plot dialog show up quickly?
Are you able to plot to PDF or DWF quickly?
Does this help? http://autodesk.blogs.com/between_the_lines/2005/12/slow_plot_dialo.html
Are your printer drivers updated?
Is it slow to plot all the files or only some in particular? Try a new file with a few lines, do you get the same result?
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
bc0120
Message 3 of 4 (1,734 Views)
07-30-2012 12:23 PM in reply to: luconceicao
I just bought a brand new computer for work, I installed AutoCAD 2012 and it takes everytime, when using CTRL + P, up to 30 secs to get just to the plot layout. Then, when I changed the setting "what to plot" or "paper size", THAT takes up to 15 secs. FINALLY actually plotting takes up to about 15 secs again. If I plot out a lot of documents it will take me a long time to finish.
However, changing paper size and previewing with other plotters seems to be fast. It is just one plotter...so I am looking into this but would like your advice.
Product Support
luconceicao
Message 4 of 4 (1,721 Views)
07-31-2012 07:02 AM in reply to: lconroy
The previous suggestions and tests also apply to you.
If this is happening only with one plotter maybe you could reinstall the driver or check if there is a new driver available from the manufacturer.
Cheers,
Luciane
