AutoCAD Forum
plotting the AutoCAD drawing using DWG To PDF.pc3.
4 REPLIES 4
Manicbala
490 Views, 4 Replies
While I'm plotting the AutoCAD drawing using DWG To PDF.pc3. I need only the drawing file name. I don't want layout name after the file name (See highlighted in attached Image 1). Everytime I need to delete the layout name and then plot the file. Is any option to rectify this?
Kindly help..
Bala
Tags (1)
4 REPLIES 4
in reply to: Manicbala
Use the EXPORT to PDF option, then apply your page setup.
Manicbala
Thanks for your help.
But it will take long time when compared to normal plotting.
Bala
pendean
Customize with Lisp, there is no core built-in ability to do so simply.
Customization forums are here if you need help http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
Manicbala
in reply to: pendean
Thanks for your information..
Bala
”Boost
