AutoCAD 2010/2011/2012
Distinguished Contributor
andrew.warren
Message 1 of 6 (187 Views)
PLine End Settings
187 Views, 5 Replies
03-15-2012 02:49 PM
Didn't their use to be a control for how PLines showed up at intersections when you increased the width? I can't remember where it was (dialog box, options, sys-var)?
Andy Warren
BCDesign@bellsouth.net
pendean
Message 2 of 6 (184 Views)
Re: PLine End Settings
03-15-2012 02:59 PM in reply to: andrew.warren
PLINEGEN variable?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
andrew.warren
Message 3 of 6 (182 Views)
03-15-2012 03:09 PM in reply to: pendean
Not sure that is it... I have a user who has some ridiculously fat PLines he uses like a highlighter on a section drawing. It follows the contour of the ground surface on a landfill up and down. So it is pretty sporadic up and down with that. At each vertex it is like you took a piece of tape cut it off and connected the ends. so when a angle is made you see some overlap and some white space in the middle.
I tried PLineGen and I don't think it fixed for him. Any other suggestions?
Andy Warren
*Pro
nestly
Message 4 of 6 (179 Views)
03-15-2012 03:34 PM in reply to: andrew.warren
Is the PLINE any LineType other than "Continuous"?
Valued Mentor
gjrcmb
Message 5 of 6 (166 Views)
03-15-2012 04:13 PM in reply to: nestly
I think this may be a limitation in Polyline functionality.  When I create a really wide polyline (say 100 units) with very acute angles between line segments, the line segments get cutoff at the vertex.  However, if I gradually increase the angle between segments by grabbing a grip, at some point the segments coming into the vertex will be tapered into each other.  This is easier to see if you change FILLMODE to "0".
So you could maybe fillet the polyline with a radius fillet equal to the width of the polyline, but questionable this will work for all vertices if there are short line segments, or whether this is going to display the way you want it or not?
*Pro
nestly
Message 6 of 6 (158 Views)
03-15-2012 05:12 PM in reply to: andrew.warren
Anything other than Continuous Linetype produces this for me.  ( Increase LTScale to prevent breaks)
