Solved by Alfred.NESWADBA. Go to Solution.
welcome @forums.autodesk.com!
First of all please make a copy of your BAK file!
If you need the drawing repaired then the fastest option is to upload the DWG file and the BAK file.
>> i can see them in the preview box
A preview does not necessarily mean it's geometry in the drawing as the preview may have been created at another time.
You might also try to run command _RECOVER (or if XRefs are included run command _RECOVERALL).
Change to modelspace.
Next step is to verify all layers are on and thawed.
Then run command _ZOOM _EXTENTS in modelspace.
if you again see nothing make sure your property window is active (<CTRL><1>) and press <CTRL><A> to select all objects ==> what does the property window show now (how many objects does it see as selected.
Good luck, - alfred -
You are welcome, thank you for your feedback, good to know it's solved now!
- alfred -
