AutoCAD 2010/2011/2012
Distinguished Contributor
KansasCAD
Message 1 of 13 (192 Views)
Playing with solids and need help
192 Views, 12 Replies
10-13-2011 06:18 AM
I am new to doing anything with solids and 3d in AutoCAD. I have had Years of Civil 3D and Land Desktop but never had the need to get into doing solid modeling.
This is a transition box between two precast concrete culverts.  I am having trouble with an inside fillet (it strengthens the box). See picture.
What is the best way to fill in this area?  When I get it filled in I plan to merge them togther into one solid.
Daryl
Patchy
Message 2 of 13 (187 Views)
Re: Playing with solids and need help
10-13-2011 06:43 AM in reply to: KansasCAD
Like this?
From the Land of OZ
KansasCAD
Message 3 of 13 (182 Views)
10-13-2011 06:47 AM in reply to: Patchy
Yea for what I am doing that would probably work.  In reality it will probably be more like a chamfer. (Both bottom edges being extended until they intersect.  Is that possible?
Thanks for the fast reply.
Daryl
Patchy
Message 4 of 13 (179 Views)
10-13-2011 06:52 AM in reply to: KansasCAD
Yes, like this
KansasCAD
Message 5 of 13 (176 Views)
10-13-2011 06:57 AM in reply to: Patchy
Yes, exactly like that.  Now can you explain how I can do that?  Remember that I am new at this and I normally only use Civil 3D.  The help that they tried to improve really stinks in this new 2012 version of Civil 3D.  Very hard to get to help on plain AutoCAD.
Patchy
Message 6 of 13 (173 Views)
10-13-2011 07:00 AM in reply to: KansasCAD
Not that difficult, you draw the base where they are going to fillet, make it a polyline; then put a node at the top.
Use command LOFT, select the base then the point. That's all.
KansasCAD
Message 7 of 13 (169 Views)
10-13-2011 07:11 AM in reply to: Patchy
I got it done but it created a Surface (Loft).  Can that be converted to a solid so I can merge it with the other two pieces of the chamfer?  I want to merge them so I can get a total volume when I get finished.
Daryl
Patchy
Message 8 of 13 (161 Views)
10-13-2011 07:18 AM in reply to: KansasCAD
Union command will glue them together.
Massprop command will list the volume.
KansasCAD
Message 9 of 13 (159 Views)
10-13-2011 07:21 AM in reply to: Patchy
It doesn't seem to work for me.  here is the drawing.  It is in 2012, I hope that is OK. If not let me know and I will try to save it back.
Thanks again for all of your help.
Daryl
Patchy
Message 10 of 13 (154 Views)
10-13-2011 07:32 AM in reply to: KansasCAD
Type in Region, select the base polyline, then loft.
