AutoCAD 2010/2011/2012
Member
Mead8803
Message 1 of 7 (249 Views)
Accepted Solution
Place and rotate
249 Views, 6 Replies
10-04-2012 06:27 AM
I work on mostly fire alarm drawings and for instance i have 4 different horn strobe symbols (one facing each direction) and i would like to make just one symbol that when i place it into a drawing i then after placing it decide what direction i want it to face. i am figuring that i need to do something when making the block that i am using. someone please help. Thanks.
Hi using a dynamic block is your answer.
I to work on fire systems & have now got one dynamic block to replace many standard blocks. I added a rotation action to the horn so that the central part stays the same as does the text & attributes. I did have to "play around" with it at first but now it works well.
I also added to the end of the visibility state name the part number of each type, added an invisible attribute made this a field which is the visibility state name so that you can get a list of the different types using data extraction.
Good luck took me some time but worth the effort.
*Expert Elite*
Patchy
Message 2 of 7 (241 Views)
Re: Place and rotate
10-04-2012 06:36 AM in reply to: Mead8803
No need for anything special, when INSERT, it will ask you. Move the mouse and that's it.
Member
Mead8803
Message 3 of 7 (231 Views)
10-04-2012 06:50 AM in reply to: Mead8803
ok yea i know how to rotate objects but i need to have the letter inside of the object to stay while i rotate the object to whatever side i need it to be on. i want a block that i pull off my tool palette, place, and then determine what way the symbol will face, while keeping the letter inside the block facing the correct way.
*Expert Elite*
Patchy
Message 4 of 7 (227 Views)
10-04-2012 06:56 AM in reply to: Mead8803
*Expert Elite*
leothebuilder
Message 5 of 7 (215 Views)
10-04-2012 07:12 AM in reply to: Mead8803
Create a dynamic block
Valued Contributor
lesleys
Message 6 of 7 (208 Views)
10-04-2012 07:54 AM in reply to: leothebuilder
Member
Mead8803
Message 7 of 7 (194 Views)
10-04-2012 08:29 AM in reply to: lesleys
thank you i will give it a whirl.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
