The problem seems very simple. My 'conceptual' or any other visual style viewports plot pixelated, while the legacy wireframe plots perfect. It pixelates everything, linework, edges, fonts. Of course I could just use wireframe, but then what is the point of visual styles I can't use?
In the same drawing with more than one viewport, the viewport with any visual style other than wireframe will mess up while the other one is fine. I have tried every printer, pdf printer, and all the dpi settings I can get ahold of.
As you can see below, the 3 is pixelated, while the 7 is not.
My goal is to plot relatively high-res drawings of 3d objects with the "conceptual" look, because wireframe shows hidden lines and doesn't show the surfaces..
Is there a way to get that same solid-object look but in vector?
If not, is there a way to increse the resolution of that raster conversion? It seems oddly low-res.
