Well here's the puzzle, on reproducing DWG to PDF, there are some texts thru-out the drawing that do not spell out, in place of the text there is a line of 'DOTS' .......
Why does this occur, how to correct this frustration. I have been using Arial and Verdana, two of very common usage for Autocad texting.
thank you,
Solved by greg_battin. Go to Solution.
Below are the steps that I send to users at work.
Here is how to change the settings for a .pc3 file and also create a new one that retains the changes that you make.
Back in the Plotter configuration Editor click “Save As” (I ask the users to do this because we have an application that overwrites this .pc3 file...)
Click OK to exit.
You may need to restart the PLOT command in order for it to refresh and see the new .PC3 file.
But after that you should be able to plot with all fonts…
~Greg
Fantastic, great solution, the project is saved !!!
let me run with it. thanks a million.
