Yet another issue I'm having with AutoCAD...
Symptoms:
-See attached drawing
-One drawing is what it SHOULD look like.
-The other is the problem I'm having
What I have done:
-The problem didnt exist one day, and the next day it started.
-The print preview looks perfect... but when I open the PDF, it looks like the attached file.
-When I open the same file with another computer, it works fine. (same autocad too)
-When I print it to my printer, I have the same issue.
Any suggestions!?!?
Solved by jjpatino. Go to Solution.
A closer look and I noticed the object in the BAD image the surfaces were not as round as the GOOD image. So i found that the difference was in the Driver of the performance tuner. when I changed that to AUTOCAD, it went back to normal.
