AutoCAD 2010/2011/2012
Active Member
ChrisHomer3621
Message 11 of 37 (931 Views)
Re: Found the Fix for the AutoCAD 2010 PDF Printer
04-01-2009 01:21 PM in reply to: DW95Grad
EDIT: Sorry, feel like an idiot. Realized that I didn't delete the PC3 file and rename the new. Once I did that, all is well.
DW95Grad,
Was the fix you posted below just to use through Plotting or for Publishing/Exporting to PDF?
I am successful in Plotting to PDF, just can't get Publishing/Exporting to work. Went through the repair and also recreated the pc3 file. I submitted my own support ticket, just thought I'd ask.
BTW, I'm utilizing LT 2010, so not sure if it makes a difference or not. Edited by: chrishomer3621 on Apr 1, 2009 8:26 PM
Valued Contributor
Rikkes
Message 12 of 37 (931 Views)
Re: PDF Printer Problems in AutoCAD 2010
04-02-2009 01:29 AM in reply to: DW95Grad
Hi!
I've got the same problem. When I want to publish to PDF it doesn't work. A single PDF print works allright!
I've set publishallocate to 1 (it was 1 allready).
This is the error message.
Job: - Canceled
Job ID: 5
Sheet set name:
Date and time started: 2/04/2009 10:18:08
Date and time completed: 2/04/2009 10:18:19
UserID: Admin
Profile ID: Rikkes
Total sheets: 2
Sheets plotted: 1
Number of errors: 1
Number of warnings: 0
Sheet: F Speelhoek woonkamer-Beginblad - Plotted with Error(s)
File: \\Server\data (d)\BOOM\Jobs\EXID\Mc Cullough\Plannen\Plannen meubilair\F Speelhoek woonkamer\F Speelhoek woonkamer.dwg
Category name:
Page setup:
Device name: DWG To PDF.pc3 - plotted to file
Plot file path: \\Server\data (d)\BOOM\Jobs\EXID\Mc Cullough\Plannen\Plannen meubilair\F Speelhoek woonkamer\F Speelhoek woonkamer.pdf
Paper size: ISO expand A4 (210.00 x 297.00 MM)
ERROR: Internal Error: Null Pointer
Sheet: F Speelhoek woonkamer-Beginblad - Error(s) Did Not Plot
Category name:
Page setup:
Active Member
ChrisHomer3621
Message 13 of 37 (931 Views)
04-02-2009 06:38 AM in reply to: DW95Grad
Rikkes,
I would try the Recreating the DWG to PDF.pc3. It won't let you save it as the same name so just name it something else. When done, delete the original and rename the new back to the original name and see if that helps.
That is what I was able to do to fix my issue.
Chris
DW95Grad
Message 14 of 37 (931 Views)
04-02-2009 06:39 AM in reply to: DW95Grad
This fix came from AutoCAD Tech Support and was to repair the PDF function in the Publish / Export Command to PDF.
I do not know if it would be different in AutoCAD LT, But I would assume not.
I did the Repair and it took care of all the issues, I would suggest you go this route.
Cindy
DW95Grad
Message 15 of 37 (931 Views)
04-02-2009 06:43 AM in reply to: DW95Grad
Go back up in my post, I belive it was post 8
Do not redirect and rename, Tech support clearly states this will mess up functionality.
follow the last repair option with the installation CD, utilizing Repair took care of all the issues
Cindy
DW95Grad
Message 16 of 37 (930 Views)
04-02-2009 06:45 AM in reply to: DW95Grad
Again as I was told by AutoDesk Tech Support the repair option is the bext route to correct the PDF function in the Publish / Export Command to PDF.
Do not redirect and rename, AutoDesk Tech Support clearly states this will mess up functionality eventually.
Follow the last repair option with the installation CD, utilizing Repair took care of all the issues.
Cindy
Distinguished Contributor
huycke
Message 17 of 37 (930 Views)
04-02-2009 07:02 AM in reply to: DW95Grad
I agree with Cindy. I had the same issues. Once I used the repair option, the PDF issues seems solved.
Steve
Valued Contributor
Rikkes
Message 18 of 37 (930 Views)
04-02-2009 08:20 AM in reply to: DW95Grad
What the ...., I've reinstalled the whole stuff. Guess what happens now...
When I decide to plot to PDF, the paper size is set to VGA! I can't choose A4 of A3 paper size.
I can't change it from pixels to mm... Not even a single PDF works anymore. Heeelp!!! Edited by: Discussion Admin on Apr 2, 2009 2:27 PM
Member
rl.tennal
Message 19 of 37 (930 Views)
04-02-2009 09:07 AM in reply to: DW95Grad
This information help me get everything working.
New Member
Isocab
Message 20 of 37 (930 Views)
04-15-2009 07:48 AM in reply to: DW95Grad
Hi all,
Same problem here, tryed to repair but still not working!!!!
What's going on here, since the 2007 version there's always someting wrong with the program, is this new versions tested?
Also on my rightclick customization was something wrong, by draworder was nothing to select (bring above - send to back - ...).
Is it possible that there's going something wrong because we take over the migration settings from the 2009 version?
kind regards,
Dean
