AutoCAD 2010/2011/2012
Distinguished Contributor
JIMDONALDSON6595
Message 1 of 9 (596 Views)
PDF and Raster Overlay
596 Views, 8 Replies
03-16-2011 06:59 AM
I'm doing some custom macros and I can't find the command to load and unload PDF's and Raster files.
Anyone know them?
Jim
*Expert Elite*
rkmcswain
Message 2 of 9 (595 Views)
Re: PDF and Raster Overlay
03-16-2011 07:04 AM in reply to: JIMDONALDSON6595
Anyone know them?
Jim
PDFATTACH
See also: AutoCAD Command Reference
JIMDONALDSON6595
Message 3 of 9 (556 Views)
03-16-2011 11:15 AM in reply to: rkmcswain
Thanks, but not what I'm looking for. For a macro to work I need the keyboard commands. Waiting for a dialog box is a waste of time I'm trying to avoid.
Jim
*Expert Elite*
rkmcswain
Message 4 of 9 (554 Views)
03-16-2011 11:21 AM in reply to: JIMDONALDSON6595
Jim
Prefix the command name with a hyphen to bypass the dialog.
If you call the command using autolisp, the hyphen is not always required.
This information is also found in the AutoCAD documentation referenced above. Did you happen to look up the IMAGE and PDFATTACH command? Also see details here
JIMDONALDSON6595
Message 5 of 9 (540 Views)
03-16-2011 02:09 PM in reply to: rkmcswain
R K
Thanks for the reply. Yes I looked up the commands on the command list. And Yes I knew about the - prefix for bybassing dialog boxes. Unforetunetly neither of those suggestions helped. App[earently you can unload a PDF or Raster file from the dialog box by right clicking on the appropriate file name. But I cannot find and specific AutoCAD command to to it from the command line.
I have found a sorta solution (is there any other kind in AutoCAD lately).
If I use the PDF / Image adjust command. I can change the contrast to view or not view the appropriate file.
Jim
*Expert Elite*
rkmcswain
Message 6 of 9 (538 Views)
03-16-2011 02:21 PM in reply to: JIMDONALDSON6595
R K
You may be correct regarding no ability to detach a PDF from the command line.
Regarding your last two sentences , you mention "raster" again, so I'll mention that you can certainly detach an image from the command line (-Image command)
JIMDONALDSON6595
Message 7 of 9 (503 Views)
03-17-2011 05:40 AM in reply to: JIMDONALDSON6595
I'm not looking to detach the files, but to unload them. We get a lot of PDF or Raster files that we overlay on to a dwg, then trace over the parts we need to CAD. Depending on the quality of the attached file, it is necessary to be able to see the dwg without the overlay. A quick unload/load would be ideal, but apparently not in AutoCAD. As I mentioned the adjust and contrast settings will work fine.
Jim
*Expert Elite*
rkmcswain
Message 8 of 9 (501 Views)
03-17-2011 05:45 AM in reply to: JIMDONALDSON6595
Ok, you can still unload raster images using -Image.
*Expert Elite*
rkmcswain
Message 9 of 9 (496 Views)
03-17-2011 05:58 AM in reply to: JIMDONALDSON6595
Jim
Here is a quick "Hide/Show" for PDFs
(defun foo ( x / ent obj)
  (setq ent (car (entsel)))
  (setq obj (vlax-ename->vla-object ent))
  (vlax-put-property obj "UnderlayVisibility" x)
;;; Use like this
;;; (foo 0) to hide
;;; (foo 1) to show
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
